Previous in Forum: Wanted: Metal Spinning Services   Next in Forum: High Speed Camera for Packaging Application
Autogenuously Joining Leaded Red Brass
11/24/2009 8:11 AM
What is the best process to autogenuous join cast leaded red brass components? The leaded red brass composition is 85% Copper -5% Tin 5% Zinc 5% Lead.
I want the castings joined with no or very minimal compositional changes at the joints. A patina will be applied afterward and compositional changes will result in differences in the patina in the finished sculpture. Defects or holes in the castings also need to be repaired in a few spots. The castings are part of a sculpture, so minimal or no weld bead is desirable.
Bone Crusher
Hobbies - Car Customizing - New Member
Good Answers: 11
Re: Autogenuously Joining Leaded Red Brass
11/24/2009 11:06 PM
Red Brasses
Principal Type
Gilding Metal, Commercial Bronze, Jewelry Bronze, Red Brass
Principal Use
Jewelry, marine hardware, heat exchangers, grille work, fire extinguisher cases
Recommended Brazing Filler Metals*
Cadmium Free Alloys: Sil-Fos & Fos-Flo Series, Braze 560, 380, 452 and 402 Cadmium Alloys: Easy-Flo, Easy-Flo 35 and Easy-Flo 45
Recommended Fluxes**
Handy Flux or Handy Flux Type LT
Recommended Atmospheres Type - Maximum Dew Point
Purified, Lean Exogas
- +10°F/-12°C, Reacted Endogas - +10°F/-12°C, Dissociated Ammonia - +20°F/-6.7°C
Remarks
In furnace brazing, flux may be used with the atmosphere for food "wetting" by the brazing alloy.
http://www.handyharmancanada.com/TheBrazingBook/Section%203/Part%2012.htm
Good Answers: 58
11/25/2009 8:01 AM
It depends on the fit-up between your castings as well as their size. If they have a precision (machined) fit, you may consider friction-stir welding, electron beam welding, laser welding, or even some form of arc welding. If fit-up is poor, you will be forced to use a filler metal. The color match will be a function of microstructure as well as composition of the filler metal.
Register to Reply 2 comments
