Previous in Forum: Internship for Gas Engineering Student   Next in Forum: Compression moulding of thin walled rubber diaphragm
8 comments
Battery
11/27/2009 3:16 AM
Hello !
I wonted to know why when we buy a a battery ( mobile phone ) we must make the cycle that we must let on charge two times 12 hours .... and after just the time needed to charge like uselly.
All the best
God bless you
Eljon Kaja ALBSECOM
Re: Battery
11/27/2009 8:38 AM
The battery is "empty" when it is new. Extended charging "fills" it up for the first time.
Then, in normal use it doesn't get emptied, just lower.
Re: Battery
11/28/2009 12:00 AM
Rechargeable batteries lose their charge over time, even when not connected to anything (self-discharge). Since the batteries are commonly sitting on shelves for extended periods before purchase by the end user, even if they had been charged at manufacture time, they would most likely have lost that charge by the time the end user bought it. That would waste time and energy at the factory, with no advantage to the customer.
Re: Battery
11/28/2009 1:34 AM
Answers so far are correct- however new technology from Varta for one means the cells are fully usable after purchase(they hold charge). Varta make a brilliant cell charger for AA & AAA NiMH cells- 5 mins from flat to fully charged!(15 min charger)- I own two- & no- I don't work for or are paid by Varta!. I just appreciate the convenience after traditional C10 charge of NiCd & NiMH cells- 14-16 hours!.
Re: Battery
11/28/2009 9:51 AM
WOW! That's interesting. Last Februrary I checked a computer made in February 1989, with a soldered-in original battery by Varta, and it still had the correct date in its real time clock! Still running after 20 years! Sounds like Varta is a good company...
Re: Battery
11/28/2009 3:44 AM
To add to present replies:
Ni-Cd batteries had "Memory" of its 1st 2-3 cycle of charge/discharge so these should be fully charged for 12-14 hours & let to discharge to their end point voltage at least 5 cycles.
It may had been overcome laely by latest technology, but it had in past & a battery recharged before its discharge to End-Point for 2/3 times will not work below that point.
About the latest types of batteries being used in Mobile devices like phones, Notebooks, Laptops, Toys may be free of the Ni-Cd bug ????
Re: Battery
11/28/2009 11:06 AM
The batteries for mobile phones these days are, almost without exception, of the lithium cell variety. That being the case, memory effects peculiar to NiCad cells are not relevant here. All you need do with a new Li cell battery is charge it fully and then use it.
Re: Battery
11/29/2009 1:02 PM
Thanks
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
Re: Battery
11/29/2009 1:02 AM
get all the goodies about batteries here.
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
Register to Reply 8 comments
dkwarner (2); Haajee (2); langyaw (1); lyn (1); Neil Kwyrer (1); phph001 (1)
