Previous in Forum: Pressure Plate on Caterpillar diesel engine 3616.   Next in Forum: mechanical pin at g.i. sheets
MECHANICAL MAINTENANCE
11/27/2009 1:44 PM
WHAT ARE VARIOUS METHODS OF RECONDITIONING TH BROKEN/WORN OUT SHAFTS
Re: MECHANICAL MAINTENANCE
11/28/2009 12:20 AM
broken shaft: replace
worn out- depending on the material, application, extent - weld/plate/sleeve/replace.
No specific answer is possible - all depends on application, stresses, material, effects of the particular type of repair on the shaft and the equipment.
11/28/2009 1:58 AM
broken shaft shuld be replaced
worn out shaft- better to used tight feet sleeve
12/02/2009 9:25 AM
equipment maintenance:-
1)prevantive and predictive maintenance of equipments
2)check list implemted
3)analysis of parameter such as viberation,alignment,smooth running,abnormal temperature and overload on equipments
these are the main factor to minimise the damage of equipments
thanks
rcmandal
07/17/2023 10:41 AM
WHAT SORT OF BROKEN/WORN OUT SHAFTS?
You might be interested in: Core Shafts and Mandrels, Rotary Shafts, Linear Shafts
