Previous in Forum: mechanical pin at g.i. sheets   Next in Forum: Online Balancing
HVAC Fans
11/28/2009 8:49 AM
Hi all,
I am finding it very difficult to find specfic information regarding the following questions, your help would be most appreciated.
a) For what reasons would a Contra-Rotating Axial Fan (i.e. two Axial fans place in a series, impellers rotate in opposite directions) be used instead of a Single Stage Fan?
b) Why is a Contra-Rotating Axial Fan used as opposed to a Multi-Stage Axial Fan (i.e. two or more fans place in a series) for this purpose?
I think it's to do with the Pa
Thanks chaps!
Biggidy
Location: N.E. Alberta 55.6329 N Lat. 111.0729 W Long. Canada
Re: HVAC Fans
12/02/2009 3:41 AM
I can think of two reasons, they may not be right, but worth a thought.
1) C.R.B. will exhibit almost no torque on the mount, as the blades will cancel each others out. A smaller one can be built and not interfere with the flow.
2) Wind flow should have less turbulence by the reduction of vortices and rotation than that would be from a multi stage inline assembly.
I'm thinking that you see this type of setup in wind-tunnels.
Could be worse, it could be me. :)
