Previous in Forum: Refrigerants   Next in Forum: Chemical Analysis Laboratory
Concrete strength
11/30/2009 1:01 PM
What is the strength in psi of concrete that breaks at 34000lbs.
Good Answers: 101
Re: Concrete strength
11/30/2009 1:17 PM
Well, If you apply that 34,000lbs over a area of 1 inch then its 34,000 psi (what is your real area?). Concrete is generally tested in what they call it's 28 day test... (28 days after cure) It is typically a 4 inch (i think) cylinder, which is put into compression until it fails... all concrete is different, and fully depends on the people making the mixture.
11/30/2009 1:31 PM
Sorry the radius is 6 in and the height is 12 in over 28 days.
Thank you
Good Answers: 101
11/30/2009 1:35 PM
Yep 6 inch radius sounds much more reasonable... its been a long time since I've dealt with any concrete strength testing... was going off a faulty memory bank.
11/30/2009 1:50 PM
Cylinders used for concrete testing (USA) have a diameter of 6-inches. Therefore the radius would be 3-inches. These cylinder are 12-inches high.
Good Answers: 101
11/30/2009 2:55 PM
grrr... radius was supposed to read diameter.. but i'm only functioning on a few brain cells this morning...
11/30/2009 6:48 PM
What is the area of the sample?
12/01/2009 3:56 PM
Your formula for PSI would be:
pressure-in-pounds
-----divided by-----
Pi * (Radius-in-inches squared)
so 34000/ (3.14159 * Radius2). not sure whether the radius is actually 3 inches or 6, just plug whichever in and there you go. either about 1200 psi or 300 psi.
Register to Reply 7 comments
Anonymous Poster (3); lyn (1); RVZ717 (3)
