Previous in Forum: steel Rst37   Next in Forum: Design Stress and Allowable Design Stress
Buckling Analysis of Pressure Vessels
12/02/2009 8:43 AM
hi all,
I want to carryout the buckling analysis of pressure vessel.
But according to asme , the buckling analysis should be carried out individually for cone, saddle etc, when the compressive stresses are observed.
How to do the buckling seperately for these components.
The components like shell cone, dished end are subjected to internal pressure.
The buckling should be tested only till yield strenth of the material?
how to calculate the critical pressure for buckling?
Please help
Pathfinder Tags: buckling analysis
Re: Buckling Analysis of Pressure Vessels
12/02/2009 10:57 AM
12/02/2009 11:08 PM
• For external pressure at shells and tubes, see UG-28 of ASME code, Section VIII, Division 1.
& For external pressure at formed heads, see see UG-33 of ASME code, Section VIII, Division 1.
See the following link: UG-28_&_UG-33
• For Stresses in Large Horizontal Cylindrical Pressure Vessels on Two Saddle Supports (Zick Analysis), see the following link: Zick_Analysis
12/02/2009 11:34 PM
Thanks for the reply,
1. the condes u have suggested is for external pressure, but which part in asme has to be referred for shell subjected to internal pressure.
2. Whether the buckling has to checked with internal pressure or by caluclating the compressive laods which are acting on the shell.
thankyou
12/03/2009 12:57 AM
• Buckling in piping and pressure vessels is related and due to the external pressure, and not due to internal pressure.
• And if you have a vessel required to be designed under both internal and external pressures, the usual procedure is to proceed the calculations first for the internal pressure, then make a check for the external pressure.
• May be the calculations as per external pressure required more additional thicknesses and/or more stiffening rings than that required by internal pressure.
• The following link is for internal pressures as per UG-27, UG-32 and Appendix 1 of ASME code, Section VIII, Division 1: ASME_UG-27_UG-32 &_Appendix_1.
12/03/2009 1:58 AM
* the vessel is subjected to only internal pressure.
if i take torispherical(dished end) part which is subjected to internal pressure.
I dont think only due to internal pressure the part will buckle, only it will bulge.
Or. instead of internal pressure, do i need to calculate the compressive loads and then i have to caaryout the buckling analysis.
There is no external pressure is acting on the vessel. I want to check the internal pressure value to which the component will buckle.
Please advise.
in this case how to solve for bukcling.
thankyou
Good Answers: 11
12/03/2009 8:24 AM
Buckling is usually the failure from axial loads. It sounds like what you are talking about is hoop stress. The reference above to ASME sections simplify the hoop stress calculations for internal pressures.
If you need to calculate buckling, you can treat this vessel (assuming it's vertical) as a column and compensate for the shape in the moment of inertia. I wouldn't use this calculation for design though (just as a ballpark check).
Register to Reply 6 comments
Abdel Halim Galala (2); Anonymous Poster (1); cingold (1); ssraja (1); woodygb (1)
