Previous in Forum: Aluminum Vacuum Deposition on Thermoplastic   Next in Forum: How to Choose a Flange
Armature Shafts: Gage Contact vs. Gage Line
12/03/2009 2:14 AM
On one drawing of "armature shaft", (a drawing on motor armature shaft), there is "gage contact" and "gage line". what is the meaning of these two terms? Sorry for the trouble~~
I am not a home work cheater. I am a translator seeking professional help
Re: one question on "armature shaft"
12/03/2009 9:28 AM
Hello wingman1985,
On machine tool spindles, the gage line is sort of like a "theoretical sharp corner" or perfect starting point. ANSI taper spindles have a gage line dimension, 2.750" on a #50 taper, for example. All critical dimensions on a spindle, or mating toolholder, are measured from this location. Even though the spindle or toolholder may vary, they are measured in relation to this perfect "gage line". "Gage contact" I am not familiar with, but if I follow my imperfect logic I would guess that is where the gage line contacts its' mating part.
Hope this helps...
