we have manufactured a mechanical rod straightening rolling machine with 4 sets of horizontal and 4 sets of vertical rolllers of 6'' dia ( in a zig zag manner) with a gear box power transmission speed,which is around 12 rounds per minute ,
we are tryng to straighten wrought iron square rod 10mm x 10mm length 6 feet to 12 feet ...but rods are not coming prefect straight ,and has to be fed several times to get straighteness thru, also rollers pressure has to be incresed and decresed ,
one more major problem is that this rods are not available in even thickness , if we buy 3/8'' sq, rods we get variations of 0.5 to 1mm tolerance + -
so my question what should be the output r p m of 6'' dia rollers?
does speed of feeding effect straightening?
what can be done for roller presses once set for inveven rods thickness?
shud be the number of rollers increased?
or you can also help me out with your own new idea if any , apart from this machine...
