Previous in Forum: Shot Blast Machine   Next in Forum: Selecting a Gear Reducer with High Level of Input Speed
regarding du bush clearence.
12/06/2009 11:31 AM
I just want to know what is the correct clearence to the shaft and bush,the shaft od is 25.5.
Good Answers: 143
Re: regarding du bush clearence.
12/06/2009 2:04 PM
Well, first of all, you might want to give a lot more information.
Then, there's this web site, GlobalSpec, that has links to suppliers - like GBB, for example - that could give you the answer.
But, assuming you mean 25.500 mm, try +0.013/-0.000 mm for the bushing bore. That, of course, is backwards since you should start with the bushing bore and throw the tolerance on the shaft, but...
12/07/2009 2:15 AM
RPM? Lubricant? Type of Bushing? ..
Design of bearing is a complicated business (assuming your bush is a journal bearing). Since the pre-load on it will depend on final operating condition. At that the minimum end-play must exist to avoid damage and metal to metal contact.
I usually leave it to designers
12/07/2009 2:36 AM
Sorry missed the DU part, for these, about 25mm the recommended clearance is between 0.114mm to 0.01mm, so you can design the shaft accordingly.
