Previous in Forum: Pumps and Motor Size Calculations   Next in Forum: Should You Join ASME?
Bolt Diameters
12/07/2009 8:03 AM
hi all
what is the bolt root diameter of M90 and M65.3 bolts according to TEMA standards
thanks
Pathfinder Tags: bolt root diameter
Re: Bolt Diameters
12/07/2009 9:21 AM
There was an earlier thread
http://cr4.globalspec.com/thread/10003/Calculating-the-root-area-of-a-bolt
Though I personally don't understand what has bolt root area got do do with TEMA? It is supposed to be as per the bolt standards. And that is available in any handbook, based on major diameter, tolerance class and pitch.
Re: Bolt Diameters
12/07/2009 11:17 PM
hi
In metric stds M90 bolt should have OD 90mm.
Depth of cut of threads =( OD - Root Dia)/2
I hope from the above Eq you will get a clearcut idea regarding root dia.
..."The truth is that there is nothing noble in being superior to somebody else. The only real nobility is in being superior to your former self...”
Location: Lincoln, England - 53° 13' 57.79? N, 0° 32' 15.58? W
Re: Bolt Diameters
12/08/2009 4:28 AM
Depth of Cut = (OD - Core Dia)/2
An example of the above equation is:
M5 x 0.80 ISO metric coarse thread - (5mm - 4.0184mm)/2 = 0.4908mm
M8 x 1.25 ISO metric coarse thread - (8mm - 6.4664mm)/2 = 0.7668mm
M10 x 1.50 ISO metric coarse thread - (10mm - 8.1596mm)/2 = 0.9202mm
To find the Core Dia transpose the formula (the hard way) or look up on a data sheet or reference table.
I don't know what TEMA is but 'Guest' is right....bolts have their own standards to conform to.
If you don't live for something, you'll die for nothing - Jamey Jasta, Hatebreed
Re: Bolt Diameters
12/09/2009 12:24 PM
There is a BS (Can't remember the number, haven't used it for some years now) which lists data for nearly every size bolt and pitch up to about 240mm dia in 5mm increments over 100mm dia and for much smaller increments below that. To work it out for M65.3 just look at a standard thread size of the same pitch and do a simple subtraction to obtain the data you require.
Be careful, there are some errors which BS are aware of but haven't put right yet.
Register to Reply 4 comments
Anonymous Poster (1); forensic steve (1); sinojkrishnan (1); soldierofmisfortune (1)
You might be interested in: Bolts, Bolt Tensioners, Anchors
