Rules for posting (especially note the section on "Do your own homework":
Look for answers before you post. Check a search
engine or two to see if you can find the answer to your question or a
collection of useful links. If it's not, or if the answer is unclear,
then that's a pretty good justification for asking the question. This
is not to stifle questions, but you're less likely to be insulted if
you have done a little research ahead of time. (thanks Silas Marner)
Provide as much information as possible. The most frustrating questions on this site are like this: "I need a sensor to test water flow - which is the best one."
What are you testing for, what are you trying to determine? Is it in a
stream, a pipe, an aquifer? Are you looking to measure velocity or
mass? Are you testing for particulates, mineral concentration or
pollution? Is it wastewater, potable water, slurry, etc.? The more you
let us know, the better the chance that someone on the site will be
able to help you find an answer (thanks Silas Marner).
Give some thought to your post title.
Don't use "Hello", "Question" or "Help". Also, simply saying "DC Motor"
is not enough. Be specific, e.g., "How Do I Install Replacement Brushes
In My DC Motor"
Please stay on topic. Posts and
comments should be of a technical nature and engage some aspect of
engineering, science or technology. If you are going to delve into
other topical areas (business, entertainment, sports, etc.), please do
your best to tie them back to one of the main focal points of this
site. Posts focusing on politics or religion will likely be removed.
There are plenty of places on the Web to talk politics or religion This
isn't one of them.
Do not post the same thread multiple times. The CR4 Admin will delete all but the most appropriate instance, or we may delete them all if we get sufficiently ticked.
Do not post phone numbers or email addresses.
The CR4 Admin will delete all phone numbers posted in threads or
comments, and we strongly urge you not to put up email addresses.
Posting your email address is an open invitation to spammers; yes, they
do crawl our site looking for easy marks. If you want to contact
someone to provide your contact information and you are a registered
user of CR4, use the internal messaging system. Keep in mind, however,
that all use of the private messaging system must conform to the Messaging Code of Conduct. Do not send spam! If you are a guest, you cannot use the messaging system, so this is another good reason to become a member of the CR4 community.
Include your country/region if needed. Some questions can only be answered "correctly" if people know where you are in the world.
Do your own homework.
CR4 is not a homework cheat site. While some here might relish the
opportunity to sharpen up old rusty skills by working the homework
problem, consider this and consider it well. If you cheat on your
homework by using someone else's answers, you are only cheating
yourself, because the purpose of any homework or other college
assignments is to help you learn - by practice, repetition, and
self-discovery. (thanks STL Engineer)
Please avoid using unsavory language / profanity. It is unnecessary to use profanity. Doing so may get your post pulled and may result in your removal from the site.
Post all advertisements in Commercial Space.
If you are posting engineering-related press releases, sales fliers,
product announcements, testimonials, descriptions of your company and
the work that it does, or any such advertising materials, please select
Commercial Space as the appropriate forum. This is the only place
within CR4 where such advertising is allowed. Please post only one
notice for your company. The CR4 admin will remove additional posts and
we may delete them all if we feel you are simply spamming the site.
