Previous in Forum: Minimizing Waste During Machining   Next in Forum: Industrial Automation Videos
8 comments
What's the Best Synthetic Rubber for Injection Molding?
12/11/2009 3:58 PM
Hi friends,
my question is that which is the best synthetic rubber to use now a days for rubber injection of a product which is used in abrasive applications?
Please also suggest the flow characteristics and vulcanizing characterisitcs for moulding purposes of the same synthetic rubber.
Re: What's the Best Synthetic Rubber for Injection Molding?
12/12/2009 7:49 AM
To answer your question, that does not mention cost:
Click here to request a
FREE
Product Design Consultation
Home
Company Articles Press Releases
Quality
Engineering Material Specifications Rubber Terminology General Considerations Design Engineers Guide
Markets Auto Medical US Gov/DOD OEM Hydronics Health & Safety
Products Custom Applications Liquid Silicone Rubber
FAQ Glossary
Contact Us
rubber & silicone products company inc and silicone rubber bulb seal
Injection Molding: Liquid Silicone Rubber
Liquid silicone rubber injection molding is the most recent addition to Jefferson Rubber Works, Inc.'s molding operations. The faster cycle times and improved performance properties of liquid silicone rubber make it a good choice for a variety of molded components. Liquid silicone rubber (LSR) remains flexible and elastic beyond -70°F and retains its properties up to 450°F which makes liquid silicone rubber a good candidate for gaskets, seals, boots, bellows, medical devices and other applications where outdoor conditions are demanding. Cured liquid silicone rubber does not out-gas volatiles and plasticizers as other rubber compounds do - which has made it friendly to various assemblies that were formerly required to be 'silicone free'.
A key advantage of liquid silicone rubber over gum based molding silicone compounds is the cycle time. Depending on the catalyst and cross-section of the molded component, the cycle times for liquid silicone molded parts range from 30 seconds to three minutes - with our average cure time of 25 to 50 seconds. In contrast, gum base silicones may take from 3 to 5 minutes total cycle time in a traditional silicone mold. Therefore, a single or two cavity injection mold will out-produce a multi-cavity mold. With fewer cavities needed to support production, tooling costs and lead times are reduced as well as part costs.
Liquid Silicone Compound Suppliers
Liquid silicone molding compounds are purchased in Part A and Part B components from the major silicone producers. These compounds are usually mixed in a one to one ratio, with pigment added during the mixing process prior to the cure. Elevated temperature and molding pressures of the liquid silicone injection molding process enhance the cure. Liquid silicone rubber is supplied to us in airtight containers, pumped from the mix metering units into the tooling without exposure to the environment - therefore humidity is not a concern and generally this liquid silicone injection molding process is more consistent than traditional molding.
Tooling considerations for Liquid Silicone Injection Molding
Liquid silicone molding involves room temperature compounds mixed and pumped into a hot mold. Tooling designs are simplified as liquid silicone rubber flows readily into very thin cross sections, tight radii and thick / thin features. Tooling surfaces do not have to be highly polished, and draft angles are not required to facilitate removal of the finished component from the tooling. When the cure cycle is complete, the molded silicone gasket can be removed without concern of distortion or tearing as the silicone is fully cured.
Silicon Rubber or Silicone Rubber? Silicone Rubber Molding or Silicone Molding?
We see silicon rubber or liquid silicon rubber called out frequently. Although silicon is often called out on prints, silicone is the widely accepted terminology used among in the synthetic rubber industry. Similarly, we see the terms liquid silicone rubber molding, liquid silicone rubber injection molding, liquid silicone molding, silicone liquid molding, liquid silicone injection molding, silicone injection molding, and silicone molding all used frequently and mostly interchangeably.
Jefferson Rubber Works, Inc. is a manufacturing agent building rubber & silicone products company inc and silicone rubber bulb seal.
Contact us about our FREE Product Design Consultation.
(not an endorsement)
Is but one of many molders using silicone.
I can't tell if you are going to mold it yourself or buy the molded parts. Molding abrasives will be hard on your tooling, but maybe you already know this.
Ask your material supplier about molding parameters on the material.
12/14/2009 10:14 AM
Dear Sam, will you be producing these yourself or having it subcontracted? Why have you choosen Injection as the methof of fabrication? (Very expensive tooling)
If you plan on suncontracting, you may want to discuss your key design criteria with a company that specializes in rubber (injection, transfer or compression molding).
What kind of abrasion will this part be seeing? Will it be used in direct contact with UV (sun) or the elements (weathering)?
Regards,
Eric
12/14/2009 10:35 AM
Dear Eirc,
Thank you for the comments.
What I am looking for is a suitable rubber material which can withstand the abrasion and heat of the applicaton which is similar to the process of a Tyre.
How much heat and abrasion does a tyre has to resist at the speed of 160 Km/hr. that is the same heat and stress which will be affecting my product in the engineering application.
Do you suggest any other method which can have the compaction and density which can be achieved in rubber injection process?
I am looking for a rubber material which can withstand the above mentioned force, speed and abrasion. What are the ideal characterisitcs of compressing such a natural rubber/ synthetic rubber in injection moulding method. I am looking to contract this method with one job worker.
12/18/2009 10:36 PM
Sam,
abrasion resistance and traction are two competing criterions. (traction happens as abrasion is accepted...therefore abrasion resistance=less traction).
Im still wondering why you need to inject this?
Eric
visit www.viconerubber.com for more info.
12/19/2009 1:37 AM
Eric,
I thought about what you said and yes you are right.
I am looking for a rubber which should be abrasion resistance and hence has a high tear strength.
As mentioned earlier the product runs at the high speed as mentioned as it is used for cutting purposes.
Hope you can suggest something. If not injection which is the best method to gain maximum density of rubber.
Sam.
04/05/2010 1:09 PM
Hey, Just wanted to pass along to the original poster a suggestion - my situation is not exactly he same but he mentioned contracting this project and I had some rubber molding work done by meere industries (meererubbermolding.com). I needed some prototypes made that had rubber bonded to metal and their turnaround time was excellent. They were able to assist with the r&d as well. Just my 2cents. Cheers, Glenn.
08/17/2017 11:44 PM
Hello everyone
We are specialized in medical silicone molding for several applications, capabilities include liquid injection molding, transfer molding, compression & more. For more info contact us at 7169722972.
08/20/2017 6:19 AM
One of the many polyurethanes may be what you want.
Generally what you want will come as a liquid which can be cast to the required shape or "painted" onto a substrate.
I'm no expert on these but think that might be an area to start looking.
Register to Reply 8 comments
Anonymous Poster (3); lyn (1); sceptic (1); Seasonal Sam (2); SILIKONTechnologies (1)
