Previous in Forum: Teflon Valve Seats for Ball Valves   Next in Forum: Replacement Fuse T3.15AL250V
11 comments
Maintenance Management Systems
12/13/2009 2:56 PM
any body need any help for implementing TPM, 5S, SMED or predictive or preventive maintenance systems ,I can help you , I joined this forum recently, its great place to share knowledge and experience , I can help whoever need help , and I can discuss if any body has any specific problem
Re: Maintenance Management Systems
12/13/2009 11:12 PM
can you share this with how to implement the TPM AND 5S.
Thanks.Sr_dur
12/13/2009 11:26 PM
Dear Guest,
Thanks for your kind gesture to share your expertise in CR4 forum. If you have any docuemnts pertaining to 5S and SMED please email it to me mrswamy@omantel.net.om
Regards
Good Answers: 114
12/14/2009 2:10 AM
It will be easier for you to help if you register
12/14/2009 4:41 AM
Dear Guest
Could you send me any docuemnts or software advise for this issue.
Thank you
Email: manuelcfortes@gmail.com
12/14/2009 1:39 PM
Hi ManuelFortes,
Read the books of Sigeo Shingo: Study of Toyota production system from industrial engineering view-point, and other titles from the same guy. Hard to read the translation but very useful. The basic idea of improvement is simple. Everyone want to do the work easier, faster, cheaper, better, and safer. Simplify, combine, and eliminate. I suggest to start with house-keeping is everybody's job. So, establish a strict program on: If it doesn't add value, it's waste. And work on "Waste of overproduction, waiting time, processing, transportation, motion, and from product defects". Also and before any other things, find for each process the bottle-neck. For example, making soap, the bottle-neck is at the filling line. Before and after the filling machine, everything is faster and easier to make. Your capacity of production must be established on the bottle-neck. It's critical to create of logical and easy way working production operation and maintenance program.
If you need more, let us know and we will supply, Gil.
Just an opinion.
12/15/2009 4:16 AM
Hi Gil
Thank you for your advise, i´ll follow your sugestion.
Best Regards
Manuel
12/14/2009 8:14 AM
Hi like any mechanical engineer i would to compare what you have with the little i consider to know. please hook me up to these info.
12/15/2009 8:42 PM
Thanks for your kind gesture to share your expertise in CR4 forum. If you have any docuemnts and soft ware pertaining to 5S and SMED please email it to me : sejati.sembiring@yahoo.com
Regards,
Sejatise
12/16/2009 10:33 AM
Hi Sejatise,
I have only books because I bought them in the 80s and 90s. With Shigeo Shingo, you can profitably read:
Suzaki's: "The new manufacturing challenge", "Work-in-process management" or more.
Schonberger's: "Japanese manufacturing techniques".
Bounine and Suzaki: "Produire juste a temps" (Produce just-in-time) in French.
Never forget to start with W.E.Deming's "Out of the crisis".
I read them, applied them, and worked well but the company's owner have to agree because with egos and other influences it will fail or don't produce expected numbers.
Wish you good reading and application of their principles, Gil.
Just an opinion.
02/08/2010 3:36 PM
Would you please sent me anything that I could use to get my maint dept working using 5s as a standard as I just took this job and is the other end of the scale
02/09/2010 10:27 AM
Hi dgstalcup,
It's absolutely necessary to own and start with E. Deming's "Out of Crisis".
After that, I suggest to buy or check out from a library: J.T. Black: The design of the factory with a future, ISBN 0-07-005551-3 (Hard cover) or ISBN 0-07-005550-5 (Paperback)
This book treats linked-cell manufacturing for superior quality at lowest possible cost with on-time delivery in a flexible way. The strategy in use is "integrated manufacturing production systems" or IMPS. It contains a full and needed references.
Also, I recommend an old but extremely practical Canadian book to eliminate manager's problems:
Robert H. Kent: 25 STEPS to getting performance problems off your desk... ISBN 0-396-08853-8 (Hard cover) or ISBN 0-396-08854-6 (Paperback)
After reading all those books and apply their recommendations, let me know your progress, and you could receive another titles. I wish you successful times, Gil.
Just an opinion.
Anonymous Poster (2); dgstalcup (1); Garthh (1); Gil Becker (3); ManuelFortes (2); mrswamy (1); sr_dur (1)
