Previous in Forum: Reverse Osmosis (RO) Water   Next in Forum: Laminated Aluminum Foil for Solar Cooker
Copper Sulfate Uses
12/14/2009 8:05 PM
Can copper sulfate be used to treat the following on ligustrum trees and hedges? Cecospra leaf spot, ball moss and spanish moss. If it can be used I need to know the rates per gallon of water.
Good Answers: 50
Re: Copper sulfate use
12/14/2009 11:05 PM
It's my understanding that almost all forms of copper are deadly to all plant life. It's kind of like the plant-version of arsenic to humans... But, I could be wrong.
Good Answers: 97
12/15/2009 1:49 AM
Yes...
http://sugarbeet.ucdavis.edu/SBPM/Pma/pma_cercospora.html
You should be able to get one of the copper sulfate compounds at a nursery/ garden type store.
The amount to use and direction will be on the label.
The following materials are licensed for control of Spanish moss and/or ball moss: Chemical control is possible. Certain copper based products like BlueShield, TC Tribasic Copper Sulphate, Basic Copper 53, Micro-Flo, Basic Copper 53, Micro-Flor Copper 3 FL are labeled for control of both moss species.
Re: Copper Sulfate Uses
12/17/2009 8:57 AM
Common treatment for mosses and fungi is CuSO4 solution mixed with equal parts of saturated solution of Ca(OH)2.
Mix the 2 solutions together just before using and spray on.
CuSO4 tends to damage plants if used alone.
Register to Reply 3 comments
bwire (1); sceptic (1); vermin (1)
