Previous in Forum: Oil Changes and Engine Types - Bikes and Cars   Next in Forum: Synthetic Brake Fluid
10 comments
Car Door Hemming Flange Strength
12/15/2009 1:15 AM
problem:- the car door assembly is made of inner panel hemmed to the door outer panel. the hemming flange does not hold the inner panel tightly. the inner panel slides once hemmed. is there any standard for hemming pressure applied to door panels.
also is there any thumb rule for the flange sizes to be hemmed.
Pathfinder Tags: hem flange hemming flange
Good Answers: 97
Re: Car door hemming strength
12/15/2009 1:37 AM
Pictures
12/15/2009 1:56 AM
the arrow shows a line on door panel-which is the separation between the inner panel and outer panel.
Good Answers: 97
12/15/2009 2:01 AM
Body panel glue may be helpful...
12/25/2009 11:16 PM
lord fusor bondiing adhesive is the answer
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
Re: Car Door Hemming Flange Strength
12/16/2009 7:33 AM
abs,
Do you work for Tata? If so, I am an old Hemmer designer (with Volvo) with 10 years experience designing tabletop and press hemmers. I would be able to do this work on contract for you. Let me know.
Dirt is for vegetables. Pavement is for racing.
Good Answers: 119
12/16/2009 11:57 AM
Hmmmm... A long, long time ago (but in this universe) I wrote an operation and maintenance manual for a GM door hemmer machine. (Note: I did NOT design the machine) I seem to remember that after the hem operation but while still in the die, tack welds were applied through the hem to the inner panel. This would assure that the hem would not spring back and that the inner panel would not have a chance to "float".
I could be wrong. It's been a long time. I do have the book in my library at home and will have to check the list of operations when I have a chance.
Hooker
12/16/2009 1:00 PM
I'll say put some dents along the hem to avoid sliding.
Pineapple
12/16/2009 1:11 PM
Welding and hammering on class A surfaces is not recommended.
12/19/2009 11:49 PM
If you want to fix it yourself, weld it with tacks every six inches and spray it with some etch primer, then paint it if you want and call it good. Just make sure to unload the door's own weight ( which will tweak it considerably ) before you work on it.
05/25/2010 1:21 PM
It is also necessary to use the HEMMING SEALER to avoid panel to panel movement.
There are lot of types are Hemming sealers available
Register to Reply 10 comments
abs (1); Anonymous Poster (2); bwire (2); Franksgarage (1); Hooker (1); Pineapple (1); unclefastguy (2)
You might be interested in: Door Operators, Door Stays and Lid Stays
