Previous in Forum: PLC Remote Monitoring and Control   Next in Forum: where do computer engineers work!!!!!
What is This Varistor?
12/15/2009 3:26 AM
I have a component looks like varistor and it parallel on the 220V feeding and it labelled
50v x185 or may be 50v x1H5 i is fault S.C
Re: varistor datA
12/15/2009 2:13 PM
Probably is a varistor (MOV), but could possibly be filter. A quick internet check didn't bring it up (but the component number looks familiar).
http://www.littelfuse.com/products.html
Are you sure it's 220Vac and not 120Vac (that would explain the 185V?? rating)?
Check the circuit to ascertain the components function, if it is a MOV just replace with something of similar voltage rating and physical size (which dictates the devices energy handling capacity).
Re: varistor datA
12/16/2009 3:43 AM
i am sorry it is on 12Vdc input
Re: varistor datA
12/16/2009 1:16 PM
What exactly is the circuit, it may help identify the part function?
Are you sure it is in parallel and not in series?
Does it have two leads or three (with the third conected to ground)?
Re: varistor datA
12/17/2009 3:55 AM
it is series not parallel an it is two leads
Re: varistor datA
12/17/2009 1:20 PM
Well it's not a MOV then. It is probably a polymeric positive temperature coefficient (PPTC) device, commonly called a "Polyswitch". They have the same distinctive package as MOVs and are commonly used as a self-resetting fuse for audio and other electronic circuits.
http://en.wikipedia.org/wiki/Resettable_fuse
http://www.google.co.nz/search?hl=en&source=hp&q=polyswitch&meta=&aq=f&oq=
