Previous in Forum: Welding Tests   Next in Forum: Inspecting Raw Materials and Fabricated Goods
WPS and PQR for SA335-P91
12/15/2009 7:34 AM
Can anyone give me any guideline or SAMPLE WPS/PQR for SA335-P91 Welding .
P91 is a ferritic alloy steel with 9 Cr, 1 Mo and same grades with V.
Its for ASME SA 335 Grade Seamless Pipe Welding by SMAW and GTAW process.
Regards
S Jana
Re: WPS and PQR for SA335-P91
02/23/2010 8:16 AM
ASME B&PV Code Section IX includes Essential variables that must be included in a WPS. You will write that WPS, and from which you will develop the PQR that proves the parameters used. Section IX has sample Forms for both he WPS and the PQR that you may use. The WPS will write itself (metaphorically speaking) by applying the standard assumptions to any welding procedure. Try it and have fun.
"Careful planning followed by rapid execution." Napoleon
