Previous in Forum: Scroll Compressor Oil   Next in Forum: WPS / PQR for ASTM A 335 - P91 Welding
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
Skew Limit For Cranes
12/16/2009 4:21 AM
i wanna no if there is any skew limit for the wheels in eot cranes. as far as i know these should be no skew in the wheeels of the crane but there is no indication in any of the standards too like IS - 3177 or IS 807. kinldy help me in ths issue. is there any other standards where i can find the details for skew in cranes.
Varun Passi
Pathfinder Tags: eot cranes skew
Good Answers: 25
Re: Skew Limit For Cranes
12/17/2009 6:00 AM
Skewing in EOT Cranes is due to non synchronisation of Long Travel motors in case of twin motor drives. If it is central drive for L.T then it can be due to misalignment of L.T wheels. You have to check the diagonals of the wheels, all the wheels should be in line with L.T rails, also there should be minimum clearance of 5 mm between rails and wheels. There can be many such reasons. It will be better to approach crane mfr to sort out this problem.
Suresh Sharma
