Previous in Forum: Electric Motors and Component Capacities   Next in Forum: Split Cores for Toroidal Transformers
India - Member - New Member
Belt Conveyor Zero Speed Switch
12/23/2009 8:35 AM
in belt conveyor system we have zero speed sensors (for safety) in tail end, which is senseing the puls from pulley/min and give the feedback its moniter, moniter is operted by 230V AC and output gentration is 8VDC for sensor operating voltage, from the moniter 1 relay with NO contact which is give the helthy comand to PLC.
I would like to know if any body suggest me any secondary options for accept above mentioning.
Plz excuse my poor english
Arun Babu
Good Answers: 29
Re: Belt conveyor zero speed switch
12/23/2009 1:25 PM
Please specify pulse sensor type, PLC type, and available I/O. Does this conveyor use drives for it's motors? What kind? How many? Is the conveyor speed PLC controlled? Explain "moniter". Standing by.
12/24/2009 1:04 AM
Using kanna electronis type sensors and relay unint. those conveyors are working in with out drives.
Moniter will sense the plus frm sensor in the moniter one continious plus generate and same will go to PLC. In PLC logic is made when plus came low it will trip the conveyor.
Re: Belt Conveyor Zero Speed Switch
12/24/2009 1:07 AM
Arun Babu
12/24/2009 8:29 AM
Not knowing all of the parameters and requirements makes all solutions hard:
But given that you have conveyors, that most likley have chain drives, they will have sprockets that drive the chain.
"Old School" the easiest method is to use a sensor on the teeth of the sprocket, in logic you can see the pulse when the teeth are moving, and when they are not.
This has been used for many years and is very dependable.
"If this fits use it, if it does not, member it, some times the simple things work, some times they don't"
12/28/2009 9:38 AM
I used to design belt conveyors, and zero speed sensors on the tail pulley shaft were the common method used for verifying proper operation.
"Obviously you're not a golfer." - The Dude
12/29/2009 3:44 PM
Can i get the diagram of your systems, which i can also implement in my ares.
Arun Babu
Register to Reply 6 comments
Anonymous Poster (1); arunbabu (2); pauls_14 (1); RDGRNR (1); williebinger (1)
You might be interested in: Round Belt Pulleys, Conveyor Rollers
