Previous in Forum: Seismic Vibration Probe   Next in Forum: intrinsic safe sov
Yokogawa CS3000 MLD block
12/24/2009 4:35 AM
hi we are facing problem with DCS MLD block we found many time we are not getting output from DCS to the positioner of the control valve later it was found that MLD block goes to manual mode ,again by putting back to auto mode we get the right output to the positioner , can anybody help out to know the cause of MLD block switching to manual mode
Engineering Fields - Control Engineering - Control Engineering Technical Fields - Education - Industrial Training Engineering Fields - Manufacturing Engineering - Manufacturing Training Engineering Fields - Electrical Engineering - Electrical engineering Training Engineering Fields - Instrumentation Engineering - Instrumentation Engineering United States - Member - New Member Engineering Fields - Energy Engineering - Become part of the larger group, change your world.
Re: Yokogawa CS3000 MLD block
12/24/2009 8:18 AM
The Manual Loader Block (MLD) is just that, allowing a manual value to be pluged into the positioner. so I believe it is a symtem of the problem, not the cause. So you best bet will be to contact the CS3000 OEM (Original equipment Manufacturere) so they look at how the DCS program is written and what instances call for using the MLD block.
AB PLC Training onsite, On-Line, training software and more. BIN95.com
12/25/2009 11:12 AM
hi there ,
do u mean to say that the whole system fault or to a particular FCS of Particular domain because so far ,we face problem on various control valves of that particular Area.
12/26/2009 12:42 PM
You need to seek out who ever wrote the program. That is what I mean. The program might need modified.
