i buy new delco remmy alternator type 300 who have voltage 24vdc but when iam use in my engine the out put is 15 vdc ,are something rong with my new alternator or other
By any chance did you get this 24 volt reading with the B+ wire unhooked from the alternator while you had the engine running? If so, there is a good chance that you have ruined some of the diodes in the alternator. Most alternators will charge between 13.8 volts and 14.8 depending on the battery temperature and the ambient temperature. Never unhook a battery or alternator when the engine is running. You can get some very nasty voltage spikes that will ruin all kinds of electronic devices.
Test first, replace parts later
