Previous in Forum: Can I replaced MRF377H by MRF377 ?   Next in Forum: High-Power, Low-Weight Lithium Battery
FPGA Output Misbehavior
01/18/2007 8:25 AM
Hello,
we`ve to do some programming of Virtex 4 - PPGA in a security-sensitive application and have the problem that the I/Os get high during configuration. Is it a "must" to disable the outputs during programming in order to have a predictable status under all circumstances with, lets say, a CPLD ??
Thank you for an answer
uweka
The sum of intelligence on earth is a constant. And the population grows and grows and .....
Pathfinder Tags: FPGA i/o behaviour
Re: FPGA Output Misbehavior
01/18/2007 10:42 AM
With no program, there is not way to configure the outputs, so they float. The solution is to use a part that is hard programmed, rather than programmed at power-up from a prom. An example would be Actel antifuse based devices. These devices can be programmed off board or on board, but, once programmed, they hold their code. So the I/O are good to go at power-up. Most FPGA manufacturers offer a family with this option.
01/18/2007 11:03 PM
That "High" state may be just the effect of a weak pull-up during configuration, say some 100K to 1Mohm, set for every I/O pin.
If you have a HIGH-DURING-CONFIGURATION (HDC) pin programmed to LOW state after configuration, and place a pull down resistor in some of the other I/Os, you may compare exactly what is going on right at the end of configuration, and may be that all of them will stay at LOW state during configuration.
Regrettably I have not used a Virtex 4 yet, but I suspect that this HIGH state of the I/Os during config is not a real HIGH State, just a very weak High State.
Jaime Soto Figueroa
http://www.matharts.cl/
01/19/2007 12:14 AM
I also used micro controller 89c52 and others all are have these same problem, intialy all ports are high in state we also did the same pull down process, its a very easier and cheaper one to make or fix a controller output in a require level , it help only at the power up state after that we can change this value through programaticaly.
Thank you for your valuable suggestions.
K.P.Mahalingam,
Electrical engineer,
India.
Every Problem has its own solution
Register to Reply 3 comments
Anonymous Poster (1); bhankiii (1); mahalingam (1)
