Previous in Forum: steam flow   Next in Forum: VFD for EOT crane LT
Stacking PCBs with High i/o.
01/18/2007 4:53 PM
Hi
I need to stack 3 PCBs with 500 contacts each.
Due to rework and x-ray it cant be a BGA connector, it can't be a through hole connector because not all the pins are extensions of the previous one. Any suggestion for a single SMT connector with 500 contacts?
thanks
Michael
Good Answers: 120
Re: stacking pcb's with high i/o.
01/18/2007 11:01 PM
divice the required connection into current carrying and signal carrying.
The current carriers will be few.
Then create some zebra strip patterns on the joining surfaces.
look up zebra strips here.
http://www.google.ca/search?hl=en&q=%22zebra+strip%22&btnG=Google+Search
What they are is a layered connector with condiuctive rubber and insulating rubber laid down as strips into a block, which is then cut to make your connector. The thickness of the conductor can be called 1 zebra width.The pads are separated by 2-4 zebra widths and a section on each side is compressed into contact. As long as the alignment is good, a strip cannot 'stray' and connect wrongly.
There are companies who make and sell these systems, contact them
Per Ardua Ad Astra
Re: Stacking PCBs with High i/o.
01/19/2007 9:02 AM
Take a look at the link below
http://www.hypertronics.com/printed-circuit-boards.html#
They have contact used in testing BGA's that may be referred to as "fuzz buttons". There are lots of contacts in a small area.
Good luck
01/19/2007 10:22 AM
You might find some of the products from Samtec of interest.
http://www.samtec.com/technical_specifications/overview.aspx?series=GFZ
for a suggested solution.
Register to Reply 3 comments
47CDPG (1); aurizon (1); rocker (1)
