Previous in Forum: Motor Oil: 15W40 vs. 20W50   Next in Forum: Linear Actuator for Continuously Variable Transmission (CVT)
20 comments
Toyota Pickup Trucks - Not a Tacoma?
12/28/2009 8:37 PM
I bought my daughter a Toyota Pick-up truck that was a 1993 or 1994. Could it have been a different model than a Tacoma.
kajprida
Re: Tacoma
12/28/2009 8:56 PM
I'll throw caution to the winds and say that, yes, it could have been a different model!!!!
Re: Tacoma
12/28/2009 9:00 PM
Thanks for the answer but, "could" isn't one.
kajprida
Re: Tacoma
12/28/2009 9:43 PM
"could" wasn't my answer.
Re: Tacoma
12/30/2009 12:08 PM
Thanks.......I'll keep that in mind. Nothing worse than wasting time with people not worth the time.
kajprida
Re: Tacoma
12/31/2009 3:53 AM
you see that the Admin friends of lynlynch have once again jumped in a deleted any post that point out what sort of person he is. Make sure that you do not annoy/ disagree with any of the guris here or you will be punished.
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: Toyota Pickup Trucks - Not a Tacoma?
12/29/2009 10:03 AM
How about a Toyota Hilux? Do any of the pictures under the "Thailand" heading look like your daughter's vehicle?
12/29/2009 11:05 AM
Thanks Moose.
With the statement I just found, I would assume that it was an SR5. However I don't want to guess. I would like someone that KNOWS, to tell me.
Compact Toyota pickups gained a restyling for 1989, with shift-on-the-fly part-time 4-wheel drive and rear antilock brakes. The new ABS system was standard on SR5 V6 models, optional on SR5 4-cylinder pickups. Standard powerplants in 1990 included both a fuel-injected and carbureted 2.4-liter 4-cylinder engine, plus an available 150-horsepower 3.0-liter V6. The two 4-cylinder engines provided 102 horsepower and 116 horsepower, respectively. Standard on SR5 V6 models and optional on Xtracab Deluxe pickups was the 3.0-liter V6. The carbureted engine offered a 4-speed manual gearbox, while the other two came standard with a 5-speed manual, with an available 4-speed overdrive automatic.
kajprida
12/29/2009 11:50 AM
While not really a Toyota guy, it appears the Tacoma did not enter until 1995:
http://www.automotive.com/used-cars/11/toyota/tacoma/index.html
With this information, it appears the answer to your question "Could it have been a different model than a Tacoma." is YES.
In '93 and '94, Toyota pickups were offered in Base, DLX, and SR5.
To end speculation, use this link: http://www.decodethis.com/ It will decode the vehicle VIN, and supply that which you seek.
12/29/2009 12:46 PM
Great
Thanks
kajprida
12/29/2009 10:33 PM
Older Toyota trucks didn't have an actual name. They only had one model, with a few versions. They were just called the "Toyota Truck".
Hobbies - Automotive Performance - New Member
12/30/2009 10:28 AM
The guest was correct in his desription of Toyota truck "naming"...a small bit of advice...Look up the codes on the the VIN , and you change all the coulds into woulds...;-)
12/30/2009 11:54 AM
If I still had it....................I woulds of.
kajprida
12/30/2009 11:48 AM
Early Toyotas sold in the states were desginated "Pick-up" - at least that's how they show up at the local Autozone. O'Rielly's shows them as "Hi-lux". I can't be certain about how they were named for Canadian sales. I will tell you that my '92 2 wheel drive has 485XXX miles on it and still runs fine. Just make sure to change the oil and filters on a regular basis and she'll have a lot of trouble free miles.
12/30/2009 12:59 PM
Is it wider than a standard Toyota P/U, maybe it's a T100?
Also did you happen to check the title?
12/30/2009 1:36 PM
I have't seen it for 5 years. Let's keep it simple guys.
kajprida
12/30/2009 2:04 PM
Wha...???
Reference #12.
If you sold it 5 years ago, why does it matter now what it was?
12/30/2009 6:32 PM
What? I was having as discussion regarding the name of his wifes Toyota truck when they met.
What does that matter to you. I thank you all. The disussion is over...........DUH.
kajprida
12/31/2009 10:14 AM
DUH? Canadian? Must be from California ;-]
12/30/2009 8:08 PM
I had an '89 - long before "Tacoma". I think they are pretty much the same, or at least what my "Pickup" evolved into, just a new marketing thing they came up with. I seem to remember the same - Basic, Deluxe, and SR5. Hi-Lux sounds familiar as well, but then again I'm in the U.S. - I would assume that all bets are off for Canada, but I guess we all know what happens when one assumes now, don't we! I have seen other models in other countries that I often wished were available in the U.S., but it was not to be.
"Being unconquerable lies within yourself." - Sun Tzu
12/31/2009 12:10 AM
I owned a 1994 Toyota 8100, S/B P/U. This model was made from 1992 - 1994. In 1995, Toyota started making the Tacoma.
Register to Reply 20 comments
Anonymous Poster (3); Doorman (2); doycon@shaw.ca (7); Dr Tom (1); ibrianrichardsmith (2); lyn (2); Sleddriver (1); Steve Melito (1); Ti QE (1)
