Previous in Forum: Signal Booster Diagrams   Next in Forum: correct way to install nut and bolt on steel lattice tower
TV Antenna Question
12/30/2009 5:32 AM
Dear Friend
As you know some kind of TV antenna rotate by a rotor .the rotor power is supplied by Main antenna wire (the wire that carry sound and image signals).I am looking for a circuit and description to make a board for this problem. How should you lead me?
It will be appreciated if you could direct me to a correct way
Thanks
Touradj
Re: A little question bout tv antenna
12/30/2009 5:37 AM
Re: TV Antenna Question
12/30/2009 9:48 AM
Every antenna rotor system I've worked on have separate cables for the RF signal (from the antenna) and for the antenna rotor.
12/30/2009 12:37 PM
It's called a diplexor or duplexor. Implies combining signals of different frequencies (HF AC and DC)
Basically one can pass DC through the coax center conductor and braid cables. A choke in the DC path strips off the rf so that the motor and controller won't get damaged. Then insert and take off AC signals by tapping in a capacitor (.1 - .001 depending on low freq cutoff) at each end of the DC path to run.
This does come at a cost of some signal strength.
Sorry about the lousey drawing. R= rotor, C= controller, tv= tv , cap and choke in drawing.
Register to Reply 3 comments
Anonymous Poster (1); kemavisjr (1); redfred (1)
You might be interested in: Rotor-Stator Mixers, Antennas, Radio Transmitter ICs
