Previous in Forum: turning issue for SUS 304 with cam machine   Next in Forum: U Stamp
India - Member - New Member
API 614 - Lube oil system
12/31/2009 4:20 AM
What I understood is that, when ever we say LO System reqd. as per API 614 Chapter-2, It means Both Chapter-1 + Chapter 2 are applicable.
Same way for Chapter-3 Lube oil system - Chapter 1 + Chapter 3 is applicable.
Means, Chapter-1, that is General details for Lube oil system are to be consider with either chapter 2 or 3 or 4.
Is my understand is correct.
Pathfinder Tags: API 614 - Lube oil unit
Re: API 614 - Lube oil system
01/06/2010 8:49 PM
Yes you are correct. In the 5th edition, they refer to the chapters as Parts, so now you say Part 1 & 2 or Part 1 & 3. This follows more of the ISO terminology.
