Previous in Forum: DCS & PLC I/O list preparation   Next in Forum: Priming Lube Oil Pump
How to Detect Oil Contamination in Water
12/31/2009 9:36 AM
We have a lube oil cooler where the hot lube oil is flowing at a pressure of about 28 barg on the shell side.The tube side contains water at around 4 barg.
We are interested in detecting oil leakage in water when the tube has a small leak or it ruptures.
The water is a closed loop system.
Does anyone have a good experience with any simple analyzer(just a probe in the cooling water side and associated electronics instead of a full blown analysis system)
Thanks, and have a happy and prosperous New Year
If you don't know where you are going,you are bound to get there
Pathfinder Tags: oil in water
Good Answers: 29
Re: How to Detect Oil Contamination in Water
12/31/2009 11:13 AM
Take a look at this link; www.idswater.com
12/31/2009 12:12 PM
Have You Considered Agar -Water Cut analyzer
You can mount the probe on downstream Side with nozzle arrangement and measure the cut water in oil
Regards
Jose
12/31/2009 1:46 PM
That is a pretty large differential.. Why not just open a drain and take a small water sample occasionally? If there is a leak, there should be oil in the water...
01/01/2010 12:04 AM
Monitor the differential pressure between the oil side and the water side, use a switch or transmitter to generate a low DP alarm. You can also monitor oil outlet flow and temperature.
01/01/2010 12:09 AM
EOS 80 sensor from Cambria Corp in Seattle. www.cambriasensors.com
01/01/2010 9:39 AM
I'd use the same that's used when is any leak from lube syst.to water cooling system or backwards in car engines.-
Good Answers: 42
01/03/2010 11:05 AM
Add some fugitive dyes like basic / direct/ acid dyes to the oil[ minimum dosage for visible detection] and look for leaked traces in coolant water. You can also locate the leakage point in the lubrication coil. A hint learned from hydraulic flow studies.
Nature is so graceful and naked. Human possession is ridiculous.
Register to Reply 7 comments
Anonymous Poster (2); dabdool (1); ferquiza (1); RDGRNR (1); s.udhayamarthandan (1); Steve S. (1)
