Sir
I just recently relocated to the UK as a DOD civilian. I'm trying to rewire my 2006 chevy HHR turn,brake and tail light configuration. My turnlight needs to be switched to the backup light area and made amber in color. I need to wire each turn signal from the the front or from the BCM located under the console on the passenger side?? If so what colors are they coming from the BCM????Drop a wire from my brake light off the middle brake light to each brake light on each side???. Add a seperate bulb with a tail wire and brake wire???I think I need to take the combination bulb(tail, turn, and brake) out from the top rear marker on each side and tape to the inside of the panel. If there is a easier way please post and advise. I have wired in lights for trailors alot. Someone mention adding relays to keep the voltage from dropping and blowing my BCM???The hobby shop on base wants to charge me 450.00 dollars to do this. Please provide information.....
