Previous in Forum: Perry's Chemical Engineers' Handbook   Next in Forum: Owner Julia's Cleaning
Gasket Material
01/05/2010 5:58 AM
is it common to use spiral wound gasket with SS inner & CS outer ring according to NACE STANDARD
Also posted in: also posted in Mechanical Engineering
Re: gasket material
01/05/2010 6:01 AM
No.
Re: gasket material
01/05/2010 6:01 AM
Yes.
Re: gasket material
01/05/2010 11:34 PM
Maybe, sometimes.
Re: Gasket Material
01/07/2010 4:43 AM
What is the flange material?
The SS inner will take care of normal corrossion due to fluid as well as not try to contaminate it. The CS outer jacket will cut down the cost.
The Gasket jackets will be in very close contact with both the flanges. The difference in material will give rise to galvanic corrossion between one of the jackets and the flanges, unless special precautions are taken.
Why do you want to use the jackets of different material? The cost difference will not be too high to be worth it.
Re: Gasket Material
01/09/2010 12:41 AM
FLANGES MATERIAL ARE A105 NACE MR0103,I WANT TO KNOW ,THE NECCESITY OF USING STEEL PARTS OF SPIRAL WOUNG GASKET ACCORDING TO NACE MR0103 .OR WE CAN USE NOT NACE MATERIAL FOR GASKET.
You might be interested in: Metal Ring Seals, Gaskets and Gasketing, V-ring Seals
