Previous in Forum: Continuous Heating of Aluminum Alloy 6082   Next in Forum: Motor and Propeller
In Situ Determination of C Value
01/08/2010 5:02 AM
Hi...
Can anyone tell the procedure for finding out the Hazen William constant "C" in site.
Thanks and regards
Dhanya
Re: In situ determination of C value
01/08/2010 7:26 AM
When all the other variables in the formula are known, solve for C.
This is called calibration.
01/08/2010 8:30 AM
01/08/2010 11:32 AM
While I could be wrong it sounds like the original poster may be wanting to know how/see what kind of flow coefficient is actually being achieved by their pipeline in the field (not necessarily just someone else's perception/promotion of what a particular pipe would do).
One organization that I know has done a great deal of flow testing of actual pipelines in the field, with cooperation and participation of many utility customers (and incidentally also comparing some different types of ACTUAL/working pipes/pipelines in some systems), is the Ductile Iron Pipe Research Association - see summary discussions of some of such testing on their website at dipra.org.
While I suspect approximations might be had by more simple field means, I suspect DIPRA could provide upon request of a utility etc. more detailed report and/or description of instrumentation and protocols for most accurate field testing.
Re: In Situ Determination of C Value
01/14/2010 2:29 PM
dhanya, are you looking for a method of calculation (theoretical) or are you looking for a means of measurement (empirical), I.E. a flow meter?
01/15/2010 2:14 AM
Thanks for the reply,,,,, am lookin for an empirical method.....
01/18/2010 3:34 PM
I recommend you do a search on flow meters. You will find all kinds for liquid and/or gas. Sonic, turbine, differential pressure etc.
Register to Reply 6 comments
Anonymous Poster (1); dhanya (1); lyn (1); Maxxx (2); Randy Conner (1)
