That's really a very very open question - it really depends on the test standards. Are you trying to certify the shafts to an OEM spec? If so you need to read the spec and it will tell you the various criteria required for the test.
If it's for your own curiosity then you need to simulate the "normal" conditions the shaft would be used under and define a length of time. Say 3000 hrs.
