Previous in Forum: Bubbles in Paint on DM Storage Tank Wall   Next in Forum: MAKING A SNOW BLOWER!
chlorine injection
01/09/2010 7:13 AM
hi every body
i want to ask about the most recent technology for chlorine and cauastic soda injection in water projects ( pumping stations ) . we use ( prums + evapourators + regulators + chlorinators + injectors ) ( metering pumps + dosing pumps ) any other methods
thank you
Re: chlorine injection
01/09/2010 11:11 PM
For Chlorinator, you need Chlorinated water generator in which Chlorine is dissolved into water at ppm level. This is a continuous process. Such produced Chlorinated water is added through precise rotameter or injected using metering/dosing pump. Alternately ready made/bought out 'hypo solution' is also used.
Is caustic needed for your water project? Lean caustic solution can be dosed thorough metering pump as well.
Well, you are looking for recent technology, will RO help you out?
