Previous in Forum: loosening torque   Next in Forum: will overheating damage engine
15 comments
2001chevy cavalier wont start
01/09/2010 11:17 AM
I have had repeated trouble with this car.It has had a no start condition three times in five months.I have checked for air,fuel,and fire.The plugs smell of gas,but the ignition control module and coils check out o.k. I am stumped as to what to do any help would be great
Re: 2001chevy cavalier wont start
01/09/2010 11:21 AM
Is it equipped with an anti-theft device? Check the archives. I recall some type of factory device that causes problems.
01/09/2010 11:40 AM
yes it has a factory anti theft system.The light comes on during bulb check then goes out.
01/09/2010 11:59 AM
This may or may not help.
Re: Anti-theft light blinking
01/09/2010 12:05 PM
Thanks but the anti theftsystem is o.k. i tried changeing the fuel filter,with no luck.
01/09/2010 12:07 PM
Sorry. Do you have any way to check the trouble codes?
01/09/2010 12:11 PM
I am going to get a obd II scanner at autozone later.Did a scan around month ago and o2 sensor is faulty,dont think that will cause no start.
01/09/2010 12:14 PM
I quit working on vehicles when fuel injection came along, so I'll not be any help.
Good Luck.
01/09/2010 12:21 PM
Thanks anyway now with ecm's,pcu's and all the other electronics on cars other than routine maitnence you almost have to have a scanner.Hopefuly it will help me.Thanks again.
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
01/09/2010 10:33 PM
This is not an all-inclusive list, and it is possible under some circumstances to add or delete items. It is a basic performance testing menu.
Basic testing sequence:
Pre (cold) start attempt:
Check for proper battery voltage
Install fuel pressure gauge
Check for pressure and volume (check spec table in repair manual)
Install engine analyzer
Check for spark at a minimum of two cylinders
Check for injector pulse at a minimum of two cylinders
Pull codes
Check ECM/ECU data stream
Attempt to start: if starts and runs:
During running, recheck:
Fuel pressure/volume
Primary/secondary ignition scope traces
ECM data stream
Speak softly and carry a big stick.
Re: 2001Chevy cavalier wont start
01/09/2010 10:58 PM
If your plugs smell of gas you will have to clean or replace them before they/the plugs will fire! You can clean them by removing the plugs and then heating the electrode end with a torch to burn off the fuel and any deposits on the plugs!
01/10/2010 12:07 AM
I have a friend that has an 01 cavalier and her car was having starting issues just a couple weeks ago too and hers turned out to be the ignition was shorting out cost her a little over $400 to get it fixed. Not sure if that will be any help but sounds kind of simular to what she had as a prob. Good luck on your quest!
01/10/2010 4:32 AM
i don't have much info to go on but. if your plugs are wet with fuel, that condition will set a o2 sensor code. you didn't say what engine is in you car. some engines in those cars have a fuel injector set up that will allow raw fuel to inter the intake manifold if the o rings leak.
01/13/2010 8:51 AM
have done a diagnostic only the o2 code that i have had for awhile,the car has a 2.4 liter engine.
01/13/2010 2:30 PM
have tried many thingsif i dump gas in throttle body car will run then dies.Fuel pump runs but still wont start.HELP
Good Answers: 50
01/13/2010 4:36 PM
Refer to #10. The pump may run, but that doesn't mean it's working properly. You need to check the pressure and volume.
Also, it could be another fuel related problem. The injectors may not be pulsing, or may be pulsing incorrectly. Several things can prevent fuel delivery for combustion.
You need to perform some basic tests to determine the problem.
Reply to Forum Thread 15 comments
Anonymous Poster (6); dragon_slayer79 (1); Engineering Superman (1); lyn (4); scrapper (1); standarded (2)
You might be interested in: Motor Coils, Power Plugs, Plugs, Stoppers and Inserts
