Previous in Forum: How to Convert a 1940 6 volt Ford to 12 volt   Next in Forum: 2000 Dodge 200m - Problem Shifting
trans
01/10/2010 10:06 PM
I have a 1999 dodge ram van 5.2 it has to warm up before the truck will shift have already replaced the speed sensor
Re: trans
01/11/2010 11:41 AM
As I recall, the Dodge transmissions will not pump fluid untill the gear selector has been moved; that is to say, on a cold day (after startup), shift into neutral for a few seconds, then back to park, then let her warm up This will start the fluid circulating. I am uncertain when this started, but I think '99 is in the range.
Now, Mopar has this selected this function for a reason... please be careful!
Let us know if this helps.
Reply to Forum Thread
