The % of NDT, particularly X-Ray (radiography) is specified by the governing Code. It is intuitive that for High pressure steam systems, 100% is most typically required. But, check the Code, first. A good place to start is with you supplier. they may have a metallurgist that can render a the help you need. Also, check your contract documents for the Code required, and engineering requirements that may specify more stringent testing that may be required by the Code.
"Careful planning followed by rapid execution." Napoleon
