Previous in Forum: Nozzle and Silent Check Valves   Next in Forum: Central control room
Digital Electric Pulse Control
01/11/2010 3:24 PM
Is there a digital product out there that can be used as an external control for setting electric pulses? To be used in place of an armature for new motor design.
Pathfinder Tags: external armature
Re: Digital Electric Pulse Control
01/12/2010 12:06 AM
I am confused.
You are designing a new kind of motor that has an electronic circuit (digital) instead of an armature.
Sounds to me like an induction heater.
I must be really tired.
Gordie.
Logic is the art of going wrong with confidence. -- Morris Kline
Location: "Springwood", North Tamborine Mountain. Qld. OZ.
01/12/2010 5:13 AM
Yep! they're called variable pulse/(frequency) generators. Fairly common stuff. Used where the need is to controll the speed of a commutator-less motor. Current work on automotive electric propulsion conversions use them extensively. Check Google on the subject, and then go to UTube to see some in action. Cheers, Stu
"Nothing, is as it seems." Dr Wally.
01/12/2010 9:07 AM
Hi diode101,
Yes a new IC from AustriaMicro, type # AS5134, will create the 3 phase pulse timing to drive a PM or 3 phase AC motor. It is an inexpensive magnetic rotary encoder that will also communicate with a MPU or MCU serially. By coupling a diametrically polarized disc magnet to the motor shaft, the IC placed beneath the magnet will create the 3 ph timing to optimally drive the motor. The IC is programmable to allow for random rotational positioning of the magnet to the IC and motor shaft. Phase information for the assembly is recorded in the IC to provide correct phasing for motor commutation.
Regards,
Luther
There are old pilots and there are bold pilots, but there are no old bold pilots.
01/14/2010 5:54 PM
Thank you for your information. A great help. Diode101
Register to Reply 4 comments
diode101 (1); GordieGii (1); Luther M (1); Stueywright (1)
