Previous in Forum: NANOTECHNOLOGY   Next in Forum: Cavitation Technology for Saving Fuel
ELECTROMAGNATE
01/12/2010 3:31 AM
I SAW A VIDEO ON NATIONAL GEGRAPHY CHANAL 2 DAY AGO I SAW A ECLACTROMAGNATE THEY USED ONLY 4 TOURCH BATTERY AND LIFT THE 500 KG WT HOW CAN BE POSSIBLE
Re: ELECTROMAGNATE
01/12/2010 3:51 AM
Once the weight is actually touching the electro magnet the holding force is very high.
Inverse square lay, magnetic circuit...etc.
This can be demonstrated with a small DC relay, the holding current is much much less than the pull in current.
You can test this yourself with a relay and a power supply.
Good Answers: 29
Re: ELECTROMAGNATE
01/12/2010 8:18 AM
SPEL CHEK
CAPS LOCK!
Re: ELECTROMAGNATE
01/16/2010 8:59 AM
Re: Useless UnWanted Inventions: For the same reason there are so many unwanted people ?
"‘Mathematics is the language with which God hath wrought the Universe.’ Ancient Greek Mathematician_-_ CKUA.Com 'Eclectic music at its very best!’
Register to Reply 3 comments
DougRH (1); RDGRNR (1); user-deleted-1105 (1)
