Previous in Forum: ventilation system   Next in Forum: Subcooling and Steam Turbine Performance
Oil
01/12/2010 11:33 AM
Is there any moisture level acceptance limit in Lubricating oil.Pl. give some standard referance also.
Good Answers: 29
Re: Oil
01/12/2010 12:50 PM
What are you lubricating?
Good Answers: 27
Re: Oil
01/12/2010 8:30 PM
Zero is the best (but impractical number).
Conventional wisdom says 100 ppm (parts per million by weight) maximum. This is an arbitrary number which I would guess comes from a study that shows reduction in lifetime for bearings running in water contaminated oil and this is the point at which little statisically significant reduction in life can be proven.
I think that this graph comes from an SKF study, but am open to correction.
I have no special talent. I am only passionately curious. Albert E
