Previous in Forum: Design Project Incorporating a GPS   Next in Forum: Automation Project To Be done In Tank Manufacturing Industry
8 comments
Torque Required
01/13/2010 8:42 AM
hi I have been having trouble with a question and i think i've finally done it. I was wondering if there is anyone that can confirm that i've done this correct.
Here is the question: Question 3 A flywheel has a mass of 700 kg and a radius of gyration, k of 0.7 m. What is the torque required to increase the speed of the flywheel at a constant rate from 80 rev min-1 to 200 rev min-1 in a time of 20 s? Note that the moment of inertia of a body about an axis = mass*k2 where k is the radius of gyration of the body about that axis. Mass =700 Kg k = 0.7 m Current rev min-1 = 80 rev min-1 Required rev min-1 in 20 seconds = 200 rev min-1 (〖revs〗^(-1)*2π)/60= 〖rads〗^(-1) The total kinetic energy is given by the formula: Where: KE = kinetic energy in J m = mass in kg k = radius of gyration in m ωi = initial acceleration in rad/sec ωf = final acceleration in rad/sec = 63191 J Where: P = power in W E = energy in J t = time in s The power developed, P = T. Therefore T=p/ω ω = 2π (RPM/60) 2π(200-80/60)= 12.6 3159.6/12.6= 250.7 Nm so Torque Required is 250.7 Nm
Re: Torque Required
01/13/2010 9:35 AM
Good Answers: 183
Re: Torque Required
01/13/2010 10:55 AM
We do not solve home work !!!
It is not in your interest to have prechewed results or approaches.
Present your detailed computations and you will get a comment and a correction.
Re: Torque Required
01/13/2010 11:26 PM
Who are "WE"?
... like you know the answer, right?!
Guest, ask lynlynch he is one of the contribuitors ... he will answer you.
Good Answers: 183
Re: Torque Required
01/14/2010 3:56 AM
"We" = participants to CR4
I doubt that you will get an other reaction from thos who contribute constantly since it is a general policy of CR4 which you should know if you read the threads.
But I am willing to make some corrections: angular accelerations are measured in rad/s².
There are in the text several values not necessary. Rotating speed is in rad/s.
If it is a constant acceleration then its value is (max.speed-min speed)/time.
Acceleration is Vector/inertia where vector is either force or torque depending on the nature of the movement. It follows that vector is acceleration x inertia.
My result differs from the presented one. I think it is a computational error either at my end or at the other.
Good Answers: 117
Re: Torque Required
01/14/2010 10:14 AM
That sounds like a challenge!
Good Answers: 42
Re: Torque Required
01/14/2010 12:07 AM
In British units
N= rpm change, t in sseconds, W = lbs, K is radius of gyration in ft.
T = (WK^2 N)/(308t)
Question is to derive the equation and determine the constant in metric units.
Re: Torque Required
01/14/2010 10:50 AM
Like Newtons Law F= m * a
There are two components of required torque, torque by fricction and torque by aceleration.
Torque = Inertia system (kg-m2) * angular aceleration (rad/seg2)
Good Luck!!!
Grettings
R Meza
Good Answers: 183
Re: Torque Required
01/14/2010 1:35 PM
What is "seg"?
A new time unit?
As far as I know (but of course I do not know all the international unit for time is (or was) the second(E), seconde(F) or Sekunde(G) with the international symbol "s". Am I wrong?
Anonymous Poster (3); GW (1); nick name (3); Yusef1 (1)
