Previous in Forum: Pipes Damage   Next in Forum: LPG Pipeline Size Calculation
Control Valve Inspection
01/15/2010 4:03 AM
dear sir
Please tell the procedure for control valve inspection
Re: valve inspection
01/15/2010 7:19 AM
  1. obtain valve specification sheet.
  2. obtain valve.
  3. compare valve with specification sheet
  4. notify discrepancies as required
Good Answers: 29
01/15/2010 11:01 AM
01/15/2010 11:26 AM
Kind of an all encompassing question. I wont confuse the issue with more questions since control valve has a very distinct difference when relating to instrumentation and a true controlling valve as found in turbines and such.
There are historic problem areas with all valves;
Seats and Discs- Check for cracks (indications to the pure), Check contact and build up of process fluid.
Stems- Check that they run true and have good contact at back seats if back seating type. NDT? depends on application.
Gaskets and seating surfaces - Clean and inspect.
Welds - NDT
Hydro? Depends.
Balanced valves - Check stem lift to crack and travel.
Sequential lift valves - Check settings of camshafts, lift beams etc.
and on and on
If you fail to follow through, you will fail.
Anonymous Poster (1); otha (1); RDGRNR (1)
