Previous in Forum: Pipes - Bevel Ends vs. Plain Ends   Next in Forum: Test Rig for Diesel Engine
Pipe Thickness
01/15/2010 9:42 AM
Hi ,to calculate the minimum pipe wall thickness we need to three data entry
please explain about this data and the table we should use if possible use an example for me thk's
1-QUALITY FACTOR
2-CORROSION ALLOWANCE(for exp. for carbon steel pipe what's wrong some use2mm and another one use 3 mm)
3-COEFFICIENT
Good Answers: 61
Re: pipe thickness
01/15/2010 12:53 PM
I think someone has given you some wrong information.
Yes, it is good to know and apply the three factors you have , but there is more.
  • The Material of the pipe - There is a BIG difference between Copper pipe and 9-Chrome pipe
  • The Maximum Operating Temperature
  • The Maximum Operating Pressure
  • The Applicable Piping Code (B31.1, B31.3, B31.4, etc.)
  • The Commodity
Do it once and do it right
Re: Pipe Thickness
01/15/2010 11:37 PM
See my post #7 of CR4 Thread Piping Standards for Calculating Minimum Wall Thickness, and from where, see a lot of CR4 Threads.
Re: Pipe Thickness
01/16/2010 11:28 AM
• For longitudinal weld joint efficiency E (quality factor Ej), see Table 302.3.4 of ASME B31.3:
Register to Reply 3 comments
