Previous in Forum: torque limiter   Next in Forum: Radial load vs. deflection in pressurized hose?
dimension of the nut for M20 bolt
01/16/2010 2:29 PM
What is the metric dimension for a M20 nut measured from flat to flat. Any web sites with this type info. Thanks all!
Good Answers: 74
Re: dimension of the nut for M20 bolt
01/16/2010 5:48 PM
Check this link.
Bruce
01/16/2010 5:56 PM
A number of sites of hardware sellers do include a mechanism to specify bolts and nuts dimensions, and the commercially available ones. I like to use www.mcmaster.com for example.
Humm... suspicious you are...
Good Answers: 137
01/20/2010 5:44 AM
30 mm
Register to Reply 3 comments
ba/ael (1); bhrescobar (1); Codemaster (1)
You might be interested in: Nut Runners, Nut Runner Controllers, Flat Belt Pulleys
