Previous in Forum: 5.08mm Board-to-Board Connectors   Next in Forum: LTC1290CCN Chip Failure
Cables and Wires Labelling Standard
01/19/2010 9:11 AM
I am working on a power distribution design. I want to label the cables in a meaningful way, so the label contain useful information (eg.: cable type, size, cores, voltage, from/to etc) at the same time easily identifiable (eg.: unique tag+ Cable from/To ---> PW0021-MSB1/MCC1 ).
Is there any BS standard (or ANSI/NEMA standard) which specifies such labelling format?
Can someone advise any of the following standards specify such format, so I can purchase them? BS EN 50334, BS EN 60445, BS EN 60446, BS 3858?
Re: Cables and Wires Labelling Standard
01/20/2010 10:06 AM
Appreciate your reply. But they are printing machines.
I am looking for an international standard which specify power cable numbering format.
For example, ANSI/TIA/EIA 606A specifies Data centres / telecommunication systems wire identification format.
01/20/2010 10:21 AM
Regards.
I think that the format for printing is not embedded in their HW or SW. You have to give the full marking text to print on the cable lengthwise or on a lable for sticking.
These may be Batch printing or as per requirement.
I had been using different labelling machines some 10 years back and in 1990s these were quite helpful 7 fast.
Now it may be possible that you select a format but you have to feed the data for each type of cable manually or pre-record dataand automate.
Any how look for machines & their detailed data from the manufacturer's website or ask for it.
have fine day !
Good Answers: 15
01/20/2010 6:26 PM
I don't think there is an international standard. The systems we see are either sequential or are related to the dis boards. Please keep us informed if you find anything.
I came across a US navy document with the kind of system i think you are looking for but unfortunately I did not save it.
Chas
01/24/2010 9:45 PM
Check TIA-607, we will get ur information
Register to Reply 4 comments
Anonymous Poster (1); capblanc (1); cblw (1); Haajee (1)
