Previous in Forum: Gear Ratios   Next in Forum: Pneumatic Pumps
Glycol Pump
01/19/2010 4:22 PM
Can anyone advise as to what shaft material is best in a low energy, low pressure centrifugal glycol circulating pump? I am leaning toward 4140. Any thoughts?
Re: Glycol Pump
01/19/2010 6:10 PM
Glycol is not a product that requires a special resistant material. Carbon steel would do great. 4140 is a high strengh one. 4330, 4340, 4130, they all do great in theyr jobs. But, are you sure you need such a high strengh material? Maybe a good cold rolled 1045 could do it. Or even a 1020, assuming that the pump needs not to take-off so weight X strengh is not an issue. Maybe you will discover that you need bearings whith internal diameters that fit just a low carbon steel like those when you do the calculations.
Humm... suspicious you are...
Re: Glycol Pump
02/22/2010 3:55 AM
well i prefer you to go for CS or 316 SS they are much suitable for the service as said by you..
