Previous in Forum: Air Breather for Decanter Bearing Block   Next in Forum: Sheet Metal Design in CATIA V5
Installing Valves in HVAC Chilled Water Systems
01/20/2010 8:01 AM
In HVAC chilled water system, where is it recomended to install the 2way / 3way valve (i.e in supply line or return line) at AHU / FCUs?
When and where it is advised to install 3way valve in chilled water system?
Re: Installing Valves in HVAC Chilled Water Systems
01/20/2010 10:54 PM
It should be on the return side
01/25/2010 12:20 PM
Return side is correct. This is because the pressure in the coil will be higher and prevent air bubbles from getting trapped there. You use a 2 way valve typically for a variable speed pump, and a 3 way valve for constant speed pumps. Even if you had a constant speed pump, you could put a 2 way valve in on a small percentage of FCUs and the pump could ride the curve (and save some money), but you don't want to do too many or the pump could dead head or overheat.
R. Turner, P.E.
