Previous in Forum: Calibration of a speed meter 4-20mA   Next in Forum: motor instullation
IP4X
01/21/2010 12:19 AM
can anyone tel mi what is the meaning of IP4X protection
Re: IP4X
01/21/2010 12:23 AM
IP Codes
An IP code is a rating assigned to a product that indicates its level of ingress protection, that is, the amount of protection that the enclosure of the product provides against the entry of solid foreign objects (fingers, tools, and so on) and against moisture infiltration (from rain, for example). IP codes have the format IPxx, where the xs represent numerals from the coding scheme. The first number in the sequence signifies the degree of protection against the entry of foreign solid objects. The range of available numbers is 0–6 (see Table I). The second number signifies the degree of protection against the entry of moisture and may be anything from 0 through 8 (see Table II). The letter X may be used as an alternative for zero. The protection is greater as the number is higher.
Numeral
Characterization of Ingress Limit
0 or XNot evaluated
1≥50.0 mm diameter object
2≥12.5 mm diameter object
3≥2.5 mm diameter object
4≥1.0 mm diameter object
5Dust-protected
6Dust-tight
Table I. The first numeral in an IP code indicates the degree of protection from solid foreign objects.
Numeral
0 or XNot evaluated
1Dripping water: vertical
2Dripping water: 15° tilt
3Spraying water
4Splashing water
5Jetting water
6Powerful jetting water
7Temporary immersion
8Continuous immersion
Re: IP4X
01/21/2010 1:50 AM
THANKS lynlynch
Re: IP4X
01/21/2010 6:57 AM
Thanks. To arrive at this "good answer" I cut and pasted the title of your post, "IP4x" into a search engine. Something I'm confident that you can do to.
Register to Reply 3 comments
