Previous in Forum: Best Way to Cut Parts   Next in Forum: Welding, Explosions and Ammonia
Recycling PET Polymer Blocks
01/28/2010 1:37 PM
Hi,
I have PET polymer blocks (let's say 300 mm per side) and I would want to know if is possible to reduce their size to a dust with maximun particle size of 1.2 mm in one single step.
Pathfinder Tags: polymer recycling recycling
Re: PET polymer blocks recycling
01/28/2010 2:05 PM
There are machines that are used in the molding industry to regrind thermoplastics such as PET for reuse.
I don't know if the 1.2mm requirement can be met with a single pass, though.
Google regrind machines.
01/28/2010 3:46 PM
Regrinding a 300mm cube would be significantly difficult.
I suspect that a better method would be found in the timber industry equipment used to produce wood chips. I imagine something like a big power plane with notched blades instead of flat.
By the way, if you're wanting to re-process the PET in a moulding machine you would like to have no "dust" smaller than 0.7mm also. That's because fine dust stops the material flowing in the hopper throat and also through the barrel of the moulding machine.
01/28/2010 6:05 PM
"Regrinding a 300mm cube would be significantly difficult"
I don't do well at metrics. Except for a few bullet diameters, I'm pretty much illiterate. Runners and sprues aren't nearly that big though.
You are right.
Cheers.
01/28/2010 9:09 PM
Yes, I'm wondering what their source of pieces of that dimension could be. I can only guess that it's compacted recylced material in which case they should ask to have it provided in smaller blocks.
Biggest sprue portions I saw were from car bumper mouldings and even then they were barely 25mm diameter. (That's around the diameter of a 12 Gauge cartridge.)
I suffer the agony/bliss of being born in the period where it has been necessary to be ambidexterous in measurement systems and then got exposed to the challenges of "imperial" and US standards for volume and a few other less well known examples like wire gauge.
Register to Reply 4 comments
