Previous in Forum: Gas-Driven Electric Generator   Next in Forum: Bushing Material and Heat Treatment
8 comments
O Ring Selection
01/29/2010 4:09 AM
hi all,
i have to design packing case(which is used to seal the gas cylinder, and thus prevent leaking). for this packing case i need the basic formula for number of o ring required for particular pressure.
A Good Experience Comes From Bad Judgment But, Good Judgment Comes From Bad Experience
Good Answers: 183
Re: O ring selection
01/29/2010 4:39 AM
The number of O-rings is NOT related to the pressure!
The best is for you to look in a catalogue as the one of Parker for O-rings and LEARN what the component is how it works and what has to be respected for a succesful use of it.
01/29/2010 5:07 AM
Packing case and O rings ? or It is the cap?
Number of O rings=1
but properly designed with the groove and the cap OD dimensions and tolerances. I just hope that you are not experimenting with hazardous/explosive gases.
Re: O Ring Selection
01/29/2010 8:28 AM
Look at internet. Parker has a standard for groove dimensioning and o-ring specification depending on static or dynamic sealing, characteristics of fluids, etc. Just choose CAREFULLY on the tables for the dimensions and tolerances and you are done. No need to invent anything.
Humm... suspicious you are...
01/30/2010 12:08 AM
Thanks to you all.
01/30/2010 12:54 AM
Simple o'ring may not stand long for dry gas and high velocity of the plunger.
01/30/2010 10:02 AM
Probably you don't need an Oring, you need a gasket plate.
The Stillman Seal Gask-O-Seal consists of a metal or plastic retainer with grooves in one or both faces. An elastomer is molded into the groove to create the sealing element. The elastomer element may be either chemically bonded to the groove and/or mechanically locked in place by cross-holes in the retainer groove.
? Retainer eliminates seal over compression
increasing seal life
? Eliminates the need to machine costly dovetail
grooves
? Custom engineered seal design minimizes exposed
surface area to media
? Bonded seal eliminates twisting or pinching and
reduces particle generation
? One piece seal design reduces installation time/
downtime
? Bonded seal eliminates risk of improper installation
Hutchinson worldwide can help you they are expets on rubber seal.
Regards
01/30/2010 7:59 PM
If Parker O-Ring doesn't have a solution for your application, Contact Zatkoff
they have a quad ring sealing system that may fit your needs.
http://www.zatkoff.com/catalog/productsel.asp?c=48
Best Regards,
Tim
Register to Reply 8 comments
Anonymous Poster (3); bhrescobar (1); gsuhas (1); mtrivedi (1); nick name (1); yesyen (1)
