Dear Friends,
I have a question to the type of PSV(Pressure Safety/Relief valves).
- One vendor says that bellows type PSV shall be used in any superimposed variable back pressure.
- Another vendor says that Conventional type PSV can be used within overpressure limitation such as 10 or 21%(Fire case) of set pressure in single valve installation when superimposed variable back pressure is not higher than 10 or 21%.
API 520 sec. 3.3.2.2, 7th edition, Conventional type can be used in following cases.
a. The set press. has been compensated for any superimposed back pressure normally present; and
b. The max. press. during relief does not exceed the Code allowed limits for accumulation in the equipment being protected.
Question,
1.Please let me know who is right in the above two vendors(1st or 2nd) under API 520 sec. 3.3.2.2.
2.What is meaning of API 520 sec. 3.3.2.2. in detail.
