I need to find piston rings that are the same diameter for both a 2 stroke AND a 4 stroke that have oil control piston rings that can tolerate and operate properly in a ported cylinder without the oil control ring deforming, distorting and extruding into the port and breaking as it travels past the ports. As is SOP (Standard Operating Procedure) in 2 stroke engines all of the rings will have to be 'pegged' so that they cannot rotate in the ring grooves so that the ends of the rings aren't over the ports and thus catch, flex and extend into the ports and break which will destroy all parts involved. The diameter is not critical as I will design and manufacture the pistons to suit the piston rings. But an approximate diameter of 2.5" ~ 6.25 centimetres give or take would be preferable. Because of the requirements of 2 stroke piston rings, motorcycle rings are the most likely candidates for the 2 stroke rings. The oil control piston rings from a 4 stroke have to likewise be of a suitable style and construction to utilize them successfully with ported cylinders.
